Well it would be rude not for me to reply.
There are alot of different Diesel maps floating about & some have bigger draw back than others.
My 1st re-map was a Red Dot Racing map, which they had got developed from some1 else & it was quick!!
But the draw backs were, loads of black smoke, wheel spin everytime the turbo came in (1st & 2nd gear) and the clutch would judder and slip if you were in 4th or 5th and booted it!
Had the car rolling roaded & the fueling, torque and bhp were all over the shot... after 6 runs none matched!!!
Quickly went round to see nige @ Angel Tuning, where he returned the car back to standard form. Took it out for a test drive and gave her a diognostic to check everything was working just right.
He then loaded on his re-map and we went back out.
Results... it seemed slower and didn't have the kick but in reality it was slower but by 0.5sec to 60mph.... and top speed was down 8mph.
The most important change tho was, very little or no black smoke AND no clutch judder or slippage!
My car is now done over 80K on the original clutch & all's going very well!!!!
Stu, I'd contact nige and see if he knows anything about the re-map you have. If the cluch is really bad, then I'd change it and get the re-map sorted.
If it's worn this one out from normal driving ( a few map moments) then how long is another gonna last???
As for a Stilo clutch.... I'm very sure they are different and not a direct replacement. You will have to contact Nige for this info. I've been told a LUK bravo clutch will be fine upto 150bhp
cheers, Tommy
Tommy K - Have you got the Bottle!!
