Re: Engine questions... thinking of fitting a turbo from an alfa 2.4jtd to hgt, would it work?
yes m8 it would work
there is a much cheaper simple way to do it though paul
I have turbo'd a normaly aspiated car before, its quite funny actually,
easiest way to do it is get the turbo / turbo manifold and down pipe off a Coupe set up a 5th injector and off you go
I reckon if you use all the coupe manifild and turbo pipe it will bolt up to your standard bravo HGT (or after market in your case) cat and exhaust system with out too much hassle
