Lambda Sensor Removal.
D
Dan
Guest
On saturday I am changing my downpipe on my 1.2 bravo as the MOT is in a couple of weeks time and I have a hole in the flexi pipe part of the front downpipe.
I have sourced the parts 4 times cheaper than they are at fiat so its all good :)
just bought the 2 gaskets for 18 quid at fiat :s
What I'm wondering is, how does the sensor come out? is it pressure fitted or screwed in? if its the later, will I need a tool to remove it?
how tempramental is the sensor?
Any tips for removing the sensor/downpipe? tom?
Cheers all.
Dan
Time To Make A Change...you knows it...24/7
Spanner :)
It unscrews. They are quite tough things, they have to work while red hot so are not as fragile as some think.
The down pipe is held on by 3 nuts, they have a tendency to stick, so U may need to spray them with WD40 or similar 1. And U will need to go under the car.
The lambda sensor is usually screwed in, it also has a tendency to stick. If the lambda doesent come out easily, U will prob. need a flame welder to heat it up to unscrew it. I needed 1, but I didnt do it on a Bravo.
sven
glad to hear it lads :)
I'm just worried that I'll take the bloody thing out and my car will stop working!
Dan
You'd need Smee working on it to ensure it never runs again ;)
Even if U break it, you car will run, but U will fail MOT exhaust gases and the car will have a higher MPG and loose power, especially when accelerating.
sven
screw u hippy. i can sort anything me im like a mobile mechanic. im gonna be doing my brakes soon and maybe an exhaust manifold change. thats right. my car will never run again
Smee
@Tom - why is Smee always used when it comes to fuc... up things ?
sven
sven i want to know too. :( im a nice lad i pay my road taxes and ppl always putting me down..
Smee
its alright, me and my mate matt are doing it and he's fitted a full system to his a3 1.8 turbo so I trust him to help me do it :)
Car will be jacked and then put on axle stands.
and Lee, I would get someone who knows what they are doing to bleed your brakes...do you want to be able to stop ;)
Dan
isnt it like when u want to make ur self bleed just cut the veins / brake lines... hahha
hmm.. matt can fit my **** to my car. forgot about him. bloody farmers cna fix anything
Smee
ye, he can :) farmer Matt :) was meant to be going pod this weekend for run what ya brung but can't because he's "lambing" hahahahahaha.
I might take his car up the strip whilst he suffers with my fiat piece of **** :p
Dan
im tempted to buy ribzz full exhaust manifold ect cda filter superchip brakes service cambelt tints and leather retrim
i calculate 1800 needed
and car should be running good
Smee
No, cats are furry and have tails ;)
Thats a flexy pipe, allows the engine to move without snapping the downpipe.
I think mine has split!
The car has no power, sounds rough and vibrates a lot on tick over!
yes, thats the flexi pipe.
thats what has a hole in mine mate. thats why I'm getting a new downpipe as its all one piece :)
Dan
Similar threads
M
Replies
2
Views
306
M
G
Replies
1
Views
375
K
L
Replies
Views
337
L
G
Replies
Views
461
garaint
G
