HELP! Gearbox problem...
T
terry
Guest
Hi...
I have a problem with my gearbox (auto). When I downshift the gear to either 3-2-1, the gear will engage accordingly. But then when I switch back to other gears, the gearbox indicator blinks and the gear wouldn't switch anymore.
I turned off the engine and restart, then everything works ok. Doesnt happen when I switch between P-R-N or D.
I asked the Fiat dealer and he says I should just leave it on D while driving and not to downshift. Will this screw up my gearbox in the long run if I left unserviced?
Thanks...
Happened to me!
Just once and I thought I'd lost drive but it was just me being afraid to stand on the throttle with a blinking light.
Don't know what causes it but the blinking means a fault code has been stored. Restarting clears the fault becausethe ECU has a fix mode on start up.
Either ignore it or get a dealer to put it on the tester.
Where to get Auto G/Box info
Does anyone know how you can get information on the Aisan Auto gearbox?
Do they have a web site or tech support in the UK?
Similar threads
L
Replies
1
Views
579
Dark Lurker
D
W
Replies
Views
653
wakka
W
B
Replies
2
Views
408
Sabre 23
S
P
Replies
2
Views
452
Justin
J
