FIAT Auto Specialist Team
Comment
Guide Tools
<!-- google_ad_section_start -->Bypassing the Heater Matrix<!-- google_ad_section_end -->
4 hours to replace it, sod that!
Published by ben
29-05-2014
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Got coolant leaking into your passenger footwell? Then it's quite likely you've got a leaking matrix.
You could spend a day (or pay for 4 hours) to get the whole matrix replaced, or you could simply bypass it from the engine bay.
Of course you won't have any heating in the cab anymore, but then, real men don't need heaters!
The job is actually pretty simple, you just need to be brave about pulling pipes and not worrying they will break
This was done on a 2004 (15) Model - not sure if the others are the same, but anyway, it might give you some idea
Contents
<< <    Next Page: Things you will need (Page 1 of 3)    >  >>
Old 29-05-2014   #1
Trader Rating: 10
dave has donated!
Re: Bypassing the Heater Matrix
real men do need to see though, no matrix can mean no demister, this should be looked at as a get you out of trouble fix, not a permant one.
It is a whole lot better than adding the pour in crap to try and plug a hole though
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 29-05-2014   #2
ben
The Boss
ben's Avatar
ben has donated!
ben is an honorary friend of the forum :)
King Pong Champion, e+Casino Blackjack Paper Champion, President vs Invaders Champion, Funny Clown vs Balloons Champion, Table Tennis 2.5D Champion
Taiwan
Quote Originally Posted by dave View Post
For £400 - I'd rather just open the window if it's steaming up
my name is ben, i live in the east, i'm always working on the forum, i like pancakes.
MAKE MITTENS FAMOUS - https://www.instagram.com/heymittens/
ben is offline Reply With Quote Quote
Old 29-05-2014   #3
Trader Rating: 10
dave has donated!
shop around, you should find cheaper.
i had a mk3 cortina with no demister, it took all the fun out of driving.
Albert Einstein.
Old 29-05-2014   #4
ben
The Boss
ben's Avatar
ben has donated!
Taiwan
Oh the matrix is just £55 - it's the 4.5 hours labour at £75 an hour which makes it uneconomical!
Old 30-05-2014   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Too long a cold icy winter up here.....even with a heater it takes ages heating up a old diesel
Old 30-05-2014   #6
Trader Rating: 10
dave has donated!
Quote Originally Posted by ben View Post
that's a main dealer hourly rate though, should be able to find a 1 man struggling business to do it for half that, there is a dude in traders section that seemed very cheap.
this dude http://www.fiatforum.com/alfa-f-fiat...mid-bucks.html if you can get there for not much fuel
Albert Einstein.
Old 09-06-2014   #7
ben
The Boss
ben's Avatar
ben has donated!
Taiwan
Ok, for reference - there is no drainage plug, you do need to remove the bottom hose to clear it out
Old 03-07-2014   #8
Just fit a bottle of Forte cooling system conditioner / sealer,I have known this last for several years & if leak re appears fit another bottle. This stuff is amodern chemical sealer,it stays active for other leaks in the system & does not block water ways up internaly like some old makes used too. Its trade only so just find a garage that uses it & buy a bottle. Usually about £10.
oldfiatguy is offline Reply With Quote Quote
Old 30-11-2016   #9
Real men may not need heaters but a real considerate man would roll his sleeves up and get stuck in and do the job for his passengers and safety.Ken
kenuk1 is offline Reply With Quote Quote
Old 30-11-2016   #10
Trader Rating: 10
dave has donated!
Quote Originally Posted by kenuk1 View Post
real considerate men concider the date and don't post on threads that have been dead for over 2 years, the van is long gone
Albert Einstein.
Old 01-12-2016   #11
varesecrazy has donated!
This was a last attempt to keep the forums old van going.
Tinworm finished the job.
Old 01-12-2016   #12
Ooops this is just an old considerate man not looking at the date of the thread when browsing the forum. Dementia on an adventure next I suppose.Ken
Old 01-12-2016   #13
+ I have just bought my first and maybe last camper this year and the first unexpected job was to replace the by passed heater. I was told that the van overheated so they also by passed the cooling fan switch to have control. When I put another heater in I put everything back as it should be. On running the engine the fan kicks in and out as it should at 90deg just need to test now in the spring next year.Ken
Comment
Guide Tools
(T) heater matrix sod Doblo 3 01-07-2011 00:26
(T) heater matrix yellow seicento Cinquecento / Seicento 2 28-10-2009 21:14
(T) Heater matrix Graham M Punto (Mk2/2b) 8 14-10-2009 16:23
(T) Heater matrix kevstilo Stilo 6 11-10-2009 22:48
(T) Heater Matrix ratty2k Doblo 8 15-12-2007 09:43
