Thread Tools
Old 3 Weeks Ago   #1
Back on the brakes again
Quick question for anyone who knows better than me please.
Are the rear brake calipers on the 1.9 8v the same as the Vectra and Signum?
I've had a look through different threads and it looks as though it might be and there's quite a difference between the prices of replacement GM and Fiat parts so I've got my fingers crossed.
My rear right caliper's sticking quite badly now and with the MOT coming up in October it's probably a good idea to change it now rather later.
I'd rather save some s if possible though.
BrianMcL is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Back on the brakes again
Yes they are the same as the Vectra C. There are two versions though. Teves or Lucas. If you PM me your VIN I can see what ePer says.
Robert G8RPI.
g8rpi is online now Reply With Quote Quote
Old 2 Weeks Ago   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
The LH rear caliper is part No. 735364069 and RH 735364070. From the image on ePer I can tell it's Lucas as it has pressed steel guides.
Pad set is 77363607. A rebuild kit on ebay is www.ebay.co.uk/itm/352096964957
You will have to ask for a Lucas (girling) set for a Vectra C or Signum.
HTH
Robert G8RPI..
Old 2 Weeks Ago   #4
flisko's Avatar
flisko has donated!
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
whats the difference between them?
flisko is offline Reply With Quote Quote
Old 2 Weeks Ago   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
One is made by Teves,the other is made by Lucas.
They are completely incompatable. To change from one to the other you would have to change calipers, carriers, pads, disks and possibly the flexible hoses too. A easy means of identification is the Lucas uses pad guides made from thin pressed steel and the Teves uses wire pad retention clips.
Robert G8RPI.
Old 1 Week Ago   #6
flisko's Avatar
flisko has donated!
Robert G8RPI.
thats only on 1.9 rear or also on 2.4?
Old 1 Week Ago   #7
Moderator
g8rpi's Avatar
g8rpi has donated!
They list several different rear calipers. Some are common to the 16V and 20V, some not.
Thread Tools
(G) need back brakes shaneo Punto (Mk2/2b) 2 18-09-2009 20:14
(T) changing back drums brakes to disc brakes? seanMcPot Punto (Mk2/2b) 15 22-05-2009 14:44
(T) Back brakes WEDGE1967 Uno 3 26-02-2009 11:51
(T) Only back brakes working klimekkk Bravo / Brava 2 12-01-2009 10:56
Help needed for back brakes Vicks66 Newbie Central 2 08-11-2006 11:59
