Thread Tools
Old 02-08-2017   #1
Netherlands
Geatbox oil level check
Hello,
Does someone know how to check the oil in the manual gear box?
Alex71 is offline Reply With Quote Quote
Old 02-08-2017   #2
flisko's Avatar
flisko has donated!
Re: Geatbox oil level check
there is no dipstick to check
flisko is offline Reply With Quote Quote
Old 04-08-2017   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Alex71 View Post
Hello,
Usual helpful comment from Flisko.
You can't check the oil in the 6 speed M32 gearbox fitted to most Cromas. The only way to check is to drain the gearbox and put the correct quantity of new oil in. The drain plug is on the side of the differential housing at the bottom of the gearbox near where the driveshafts fit. The filler is on the top of the gearbox on a flat area. It has a hex (allen) recess. They are often very tight, you may need a hex bit that fits on a socket set extension and breaker bar. It's easier to get to if you take the battery and battery box out.
You should add 2.2 litres of new oil. The oil specification is SAE 75W-85 - API GL-4 This may be hard to find, try a Vauxhall / Opel garage if having trouble, the Vectra C uses the same M32 gearbox. There are pictures of the drain an fill plugs on this old Bravo thread, but note the use of the side level plug is incorrect, DO NOT USE THE SIDE PLUG TO CHECK THE LEVEL!
http://www.fiatforum.com/bravo/34931...il-change.html
The oil quantity was increased to prevent premature bearing failures.
Hope this helps
Robrt G8RPI.
g8rpi is online now Reply With Quote Quote
Old 04-08-2017   #4
flisko's Avatar
flisko has donated!
Quote Originally Posted by g8rpi View Post
Hope this helps
Robrt G8RPI.
wanted to type that, but i was to shy
Thread Tools
(G) Oil level check Mully59 Ducato 13 10-10-2015 22:04
(T) Oil level check Jerseywurzel Panda 7 14-10-2012 15:12
(T) Gearbox oil level check CaptainJohn2011 Ritmo / Strada 4 30-07-2012 10:54
(T) Oil level check? warm or cold don777 Barchetta 11 20-05-2008 12:40
(G) How to check g/box oil level on 97 Van. Torq Ducato 1 14-12-2006 00:45
