Thread Tools
Old 29-07-2017   #1
Fault P1714 on Croma 1.9 16v Auto
Engine management light came on and then a red flashing like with a message Check Transmission. Struggled to make the mile home. Clunking in gearbox, esp when trying to get reverse. Identified as fault P1714 - Induction Solenoid valve malfunction. Detailed "engine torque (from can) intermittent"
What and where is this solenoid? Any tips, advice, information will be very, very welcome.
angusmacdonald is offline Reply With Quote Quote
Old 29-07-2017   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Fault P1714 on Croma 1.9 16v Auto
What did you read the code with? If it's a generic reader the discription may be inaccurate. I think it refers to one of the gear box hydraulic valves not an engine valve. Another description is
Signal inductive sensor selection solenoid A
I take it youhave checked the fluid level and colour?
If you have access to multiecuscan you an check the valve solenoid voltage, current and feedback current.
I don't have an auto so can't offer much advice. Suggest you search on here.
Robert G8RPI.
g8rpi is online now Reply With Quote Quote
Old 4 Weeks Ago   #3
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
For the benefit of others. Discovered engine not firing properly in Cylinder 2. Cleaned connection. Ok for a while. Then not firing right in cylinder 3. Cleaned all electrical connect but to no avail. Decided to bitr the bucket before scrapping and put it into local Fiat agents, Mackenzie Motors Inverness for another diagnostic test. They came back with the info I alreadt knew about thse 2 cylinders but, bvless them, they had inserted tiny pins to tighten the connections and the car now runs like a sewing machine. Delighted with my re-born 2006 Croma. So if yours displays Transmission error and fault code P1714 all you need is a good local fiat agent who is prepared to do that wee bit extra and 62+vat for diagnostic test.
Old 4 Weeks Ago   #4
Quote Originally Posted by angusmacdonald View Post
"Bitr the bucket"!!!! That should read "bite the bullet"
Old 4 Weeks Ago   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
Glad to hear that it's all working. What plugs /connectors did you clean and athe garage put pins in, was it the injector connectors?
Robert G8RPI.
Old 4 Weeks Ago   #6
Robert G8RPI.
Yes. Apparently with vibration the connections can become a bit slack. I had noticed originally that when I applied pressure on connection to injector 2 that the engine ran better and later when misfiring on injector 3 the same applied. Amazing that this misfiring affected automatic transmission,giving fault code P1714.
Thread Tools
(Tu) croma 1.9 16v auto gearbox same as vaux? dieseljohn Croma 3 25-08-2012 14:13
