Thread Tools
Old 22-06-2017   #1
Sweden
Replacing door handle
Hello
I have a FIAT Croma, Multijet, model year 2006. I have bought a new exterior handle to the front door. But, I do not know how to change can anyone help me?
Thank you in advance
The Swede
Thorbjorn is offline Reply With Quote Quote
Old 22-06-2017   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Replacing door handle
Quote Originally Posted by Thorbjorn View Post
Hello
The Swede
Never done it but the technical manual, eLearn should show you how. You can download it here
http://www.fiatforum.com/downloads.php?categoryid=18
You have to extract the CD ISO file and burn it to a CD-R.
If you don't know how to do this a quick forum search should find instructions.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 23-06-2017   #3
flisko's Avatar
flisko has donated!
Hello
The Swede
http://www.fiatforum.com/croma-guide...dle-guide.html
flisko is offline Reply With Quote Quote
Old 27-06-2017   #4
Hungary
great thanks!
alexbutcher is offline Reply With Quote Quote
Old 28-06-2017   #5
s130 has donated!
I did this on my Croma a long time ago.
Here are my notes:
Stripped door down (see eLearn for trim, door handle switches removal etc.).
Unclipped glass and propped window high with top rear window edge
actually outside of the window frame to allow access to back of door handle.
Removed inner frame assembly including disconnection of door jam connection.
Followed eLearn to remove outer door handle.
Fully removed VERY STORNG handle spring which had both worn the handle platic
and broken part of the 'cage' chamber.
NOTE! When refitting handle you will find that the outside handle will be in the
up position. You have to release the 'pawl' by manually fully closing
the lock. Then the handle will drop and be lifted down by the inner lock
mechanism.
Door handle feel / action actually alot better. Softer and still returns.
s130 is offline Reply With Quote Quote
Thread Tools
(T) replacing driver's door handle and lock barrel eborus 500 2 15-07-2017 21:39
(T) Locking not working properly after replacing handle articulator Carlos4566 500 2 05-06-2017 16:45
(S) Replacing seicento gear knob/ hand brake handle Mattseicentosporting Cinquecento / Seicento 4 25-10-2012 22:58
(T) replacing door handle and tumbler Cheezy Bravo / Brava 3 11-06-2010 20:57
(T) replacing broken bonnet release handle folgore Stilo 2 09-05-2009 16:03
