Gerry Heather
- Feb 13, 2017
- 2
- 1
I purchased a Spanish registered 2.4 diesel Croma Eleganza with a few faults which seem to be vacuum related. I want to replace all the rubber vacuum pipes but am unsure of the ID sizes. I have already found the lack of turbo power was caused by a 3.5mm hose rubbing through on the chassis as spotted by other members. The EGR unit has long hoses to the pressure sensor under the car which are suspect but seem to be different sizes. The fault code for poor flow through the EGR valve returns from time to time even though the Valve is clean and the solenoid works correctly Hence thinking about vacuum leaks. Does anyone know the pipe sizes. Great car though now it goes up Spanish motorway hills faster than the trucks!!
