I apologize in advance for translation from Google.
I have a problem at Croma with a remote control. Remote control stops working when you turn off LEDs "on, off, start" to the switching cabinet.
Normally, the remote control works as soon as I open the door, for example, I light a lamp and ignition lights so it works well for both keys.
I note key internal battery replaced, the battery voltage is 12.6V.
The voltage at the fuse F23 is present. Central locking work normally.
I have the knowledge. Yesterday I broke down completely switch box after an hour of back and put the remote control worked well even when switched off The LED on the switch box.
Unfortunately, the morning the car was not unlock through remote control.
I am baffled service diagnostics Fiat does not report any error code to the ECU.
Please advise me. Does anyone have the same problem "remote control does not work?
Thank you.
Thank you.
