Technical Problem with lights
cromaamore65
Member
Nottinghamshire
Hi fellow Croma owners I have a problem with the front nearside sidelight and the rear nearside tail light. When they are switched on they go out almost immediately. The bulbs have been changed and fuses checked out with no success. I hope that you can provide reasons and solutions. Many thanks in anticipation.
Couple of basics first:
Do the the other side lights work OK, the instrument lights dim and switch illumination come on?
Do you get any warnings?
Do you have the indicator stalk in the centre position? If the indicator is down (or up) and you turn "park" mode on only one side comes on.
Other than this there seems to be no common circuit between the two lights. They are controlled by the body computer but front and rear are on different connectors. I can't identify a fuse for the side lights. It does look like it might be a body computer fault. Check all the connectors and fuses on the body computer as a first step.
Robert G8RPI.
Maybe a short on that circuit and the body computer is switching the current off to the circuit as to much of a current draw.
