Technical Croma 1.9 no ignition, check vehicle protection system
dawid926
Hello,
recently I bought a damaged Croma 2008. It was damaged left side at the height of the lower hinge of the front door. There were no problems with the start of engine.
After the dismantling of doors and other items to repair car, the ignition doesn't start .
The instrument cluster indicates only an hour and occasionally displays a message "check vehicle protection system".
During the accident gently break cover fuse box located to the left, under the steering wheel.
Fuse box was checked. The wires, fuses, relays were checked
There is also no visible mechanical damage to the PCB located in the fuse box.
I checked the cable connections from the ignition, which connect to the module located under the steering wheel.
Everything is fine, ignition sends correct signals when turning the ignition key to the ON position, has a constant 12V power supply. The 12 V also appears when I try to start the car.
Currently, the steering wheel is locked and can not be unlocked. The problem with the ignition has also performed before locking the steering wheel.
Today i change ignition and module under the steering wheel but not works.
Can anyone have any other ideas?
