I posted the tech info on the Technical Bulletin / Campaign.
My Croma wore out its original factory fit rear tyres in less than 11,500K miles.
She also passed the Technical Bulletin criteria because the wear across the tyre was even. The criteria was all about uneven wear across the tyre.
In my case (see figures below) it had excessive negative camber and excessive toe in which combined together just scrubbed the whole tyre tread surface.
When you get the 4 wheel alignment done (go for computerised 4 wheel laser align where 4 multi faceted reflectors mirror are attached to the wheels and laser beams are shone from above the car and the car is rolled forward a foot) they should have the correct data for the Croma or/if not go for Vauxhall Signum or Vectra-C settings.
I put Kilen springs all round on my Croma. No problems at all. Also Kilen springs use the same diameter wire over the full length of the spring unlike the original Fiat tapered springs which always seem to break at the thinnest part of the coil wire.
------------DATA FROM MY ALIGNMENT-----------------------------------------
FULL tank of fuel
Initial:
: Left Right Total
Front Toe : +0.11 deg -0.07 deg +0.04 deg (+0.30 mm)
Front Camber : -1.16 deg -0.78 deg -0.97 deg (average)
Rear Toe : +0.37 deg +0.14 deg +0.51 deg (+3.84 mm)
Rear Camber : -2.55 deg -2.30 deg -2.43 deg (average)
Final:
: Left Right Total
Front Toe : +0.04 deg +0.03 deg +0.07 deg (+0.53 mm) *Note 1
Front Camber : -1.17 deg -0.83 deg -1.00 deg (average)
Rear Toe : +0.10 deg +0.08 deg +0.18 deg (+1.36 mm) *Note 2
Rear Camber : -1.66 deg -1.63 deg -1.65 deg (average) *Note 3
Note 3: -1.6 deg was the lowest balanced adjustment possible whilst
keep toe-in within limits
Note 2: Small/Medium toe suggested to compensate for negative camber
Note 1: Small toe suggested to compensate for minute uneven front tyre wear
and to provide a little better handling/stability
Note: Rob explained that his father/inlaw has a Vauxhall Signum that had
excessive inner rear tyre wear and general high overall wear.
Adjusted this car to very similar figures as have just been set and
all appears to be OK.
------------OFFICAL FIAT DATA-----------------------------------------
Fiat Croma 1.9 JTD 150 16V Tracking Data 04 Nov 2010
RIMS 17.00 Inch
Standard 0 Car and 8 litres of fuel : 6.8kg
Standard A Car and 60 litres of fuel : 51.0kg
1 L of Diesel weighs 0.85kg
Owner's Manual
Standard Wheel Toe-In deg. per wheel Total Toe-in mm Camber deg. Caster deg.
working Front -0.07 +/- 0.07 -1.00 +/- 1.00
working Rear 0.02 to 0.18 +0.3 to 2.70
+1.30 (+1.4,-1.0)
Workshop Manual
Standard 0 Front -0.07 +/- 0.07 -1.00 +/- 1.00 -1.00 +/- 0.50 3.15 +/- 0.50
Standard 0 Rear 0.00 to 0.16 0.00 to 2.40 -1.33 +/- 0.50 n/a
Standard A Front -0.07 +/- 0.07 -1.00 +/- 1.00 -1.00 +/- 0.50 3.27 +/- 0.50
Standard A Rear 0.02 to 0.18 0.30 to 2.70 -1.50 +/- 0.50 n/a
Product Update 5138
Standard 0 Rear 0.02 +/- 0.08 0.30 +/- 1.20 -1.42 +/- 0.33 n/a
Standard A Rear 0.07 +/- 0.08 1.10 +/- 1.20 -1.58 +/- 0.33 n/a
Protyre Data
Standard ? Front -0.15 to 0.00 -2.26 to 0.00 -0.50 to -1.50 2.80 to 3.60
Standard ? Rear 0.00 to 0.15 0.00 to 2.26 -1.00 to -2.00 n/a
Standard A Front
Standard A Rear
Notes Rear Toe-In changes by approx +0.80 mm per 45kg
Rear Camber changes by approx -0.16 deg. per 45kg
Rear Toe-In change for full tank of fuel => 51kg => +0.91 mm
Rear Toe-In change for 70kg tow ball weight => +1.24mm
Rear Camber change for full tank of fuel => 51kg => -0.18 deg.
Rear Camber change for 70kg tow ball weight => -0.25 deg.
