biguglycar
- Nov 23, 2014
- 7
- 2
Hi, can anyone please help?
I was driving along, changing gears perfectly happily with everything behaving just as it has for the last couple of years when suddenly, and without any warning, the clutch pedal got stuck to the floor. There was no bang, no rattle, nothing. I've had release bearings go before and they seem to rumble for a while first, don't they?
After the car was towed home, I had a look at it. The clutch simply doesn't operate, so the car is stuck in neutral. The brake fluid reservoir is full. There is a puddle of what looks like very clean fresh engine oil on the floor. It is plainly not from the engine, as the oil on the dipstick is black. Looking at the underside, a matching clean fresh fluid can be seen at the very bottom of the gearbox housing, where it meets the engine block. There is no sign of fluid tracking down to that low point from anywhere else.
Any ideas what might have gone wrong, how I might diagnose further, or what the likely repair might be?
