Hi the body ecu is behind the fuse box which on rhd cars is in front of your right knee a Philips screw will expose the fuse box the ecu is behind it you might need to remove some trim to get to the ECU connectors give them a good push in and shake. To get to the column connector drop the bottom trim at the wheel it is on the left six so inches down and will work lose if you get excited with rake and reach.
