Tuning Wheel spacers
Front wheel spacers cca 5mm, rear cca 14mm.
Somewhere in between is not possible :eek: without http://www.turnermotorsport.com/p-210-turner-motorsport-front-hub-extenders-pair.aspx
I want to low down the wear difference between tyre inside and outside edges on the rear axle.
I will ask for more conservative rear camber (less negative), somewhere on the edge of the green field or little in the red :)
Spacers should help with grip. I hope so :D
I know that I will lose some but I hope that I will get some ;)
