Hi All,
Just had the pleasure of changing my battery as the original had finally given up the ghost.
Been out on a test drive to make sure everything's OK and whilst the electricity seems fine I'm having a lot of trouble changing gear. There were no problems changing gear until after the battery change.
Changes are especially stiff out of reverse and to 2nd, 4th and 6th, and when it's been in the same gear for a while it's really hard to get it to go into a different gear.
I find it hard to believe that it's directly related to the battery (the closest fit I could get was a type 110 Excide from ECP with 80a and 780CCA and yes it needed pieces of wood to hold the battery in place) but is it possible that I've dislodged something that's now obstructing the gear change?
Any help or suggestions would be, as always, greatly appreciated.
