Anyone having issues with wheel wobble or the car shaking usually 40-60mph?
Ive had a mare of a time with my Croma with this issue, fortunately now all sorted permanently.
a fiat specialist looks after mine, mentioned this wobbling as it was getting quite bad, and looking at the forum its this driveshaft and a good fix was the vectra driveshaft, mentioned this to the fiat specialist and he said as he is Italian wasnt comfortable and that a new spider joint is the start, but i would have preferred to fit a vectra shaft, anyway £170 later new spider joint on, wobble now only very minimal, hardly noticable but im fussy. my croma is used as a taxi, i went on holiday for 6 weeks to return to the croma with a new problem, drivers wheel getting very hot and no meat on the pads, specialist said caliper and pads, i fitted new caliper and pads, still the same, i then thought maybe the disc was warped as what was happening was the wheel was catching a third of the way on the pad creating friction, bought new discs (expensive on the 16v) to find problem still there, had to be the shaft.
so found a vectra shaft but there are two types f40 and m32, the specialist confirms there are no numbers on the gearbox unlike the gm cars usually f40 or m32, i took a chance and bought a vectra shaft m32, fitted it myself and the car is now fixed with no wobbling.
so i can confirm that these vectra shafts fit for the 16v jtd 150.
took me a few hrs but heres how to do it.
jack car up both wheels - quite high, remove engine tray, remove wheel, and the driveshaft nut cap, using a 32mm socket undo fully the driveshaft nut. using i think a 17mm and 11mm undo the ball joint bolt, using a ball joint splitter undo the joint and move the wheel clear. pull on the disc towards you and the driveshaft will slit and come out of the cup, you can then knock the shaft from the hub, BUT BE CAREFUL WITH THE NUT if your used shaft doesnt have one!!!
using the 11mm i think undo the three bolts securing the shaft to the sump, place a tub under the gearbox where the shaft goes in. the bracket with the three bolts needs to be slightly wedges as there are small dowels on it so i seperated it so the dowels were free of the sump and placed a slim spanner there to keep it wedged out, then tap that towards the drivers wheel so it comes out of the gearbox then remove.
feed the new shaft in, locate in the box and line up the holes for the driveshaft bracket, you will notice these are closer than the fiat system, bolt them up, feed cv end into hub, gently put the nut on (as the threads are fine), refit balljoint, torque driveshaft nut, dustcap on, put wheel on and refil gearbox of lost oil (not sure on that as took it to garage but only loses around half a cup), refit engine tray.
THEN LOOK FORWARD TO THAT PROBLEM GOING!!!!
Make sure your used shaft comes with the three bolts for the bracket as these gm ones have thick washers on them, and the bolts looks slightly shorter, and the driveshaft nut, yours should fit but i damaged mine removing the shaft from the hub as i was hitting the nut to remove it.
Mine was a m32 other posts also say m32 but they are around £25-40 used delivered, easy job if you take your time and get someone else to do the gear oil.
my car has done 67k only and ive never had a car before with so many parts to change at such low mileage, just goes to show how gm and fiat build cars - wont be having another.
any issues just ask pref by email thanks
steve
steve
