I've never needed to connect via an elm327 cable before but after having trouble with the ABS I finally bit the bullet.
It connects to the engine OK but when I try to connect to anything else I just get the ELM327 unable to connect to ECU message.
Can anyone advise what I'm doing wrong please?
It's set up as elm327 v1.3+ on a valid com port, passes the test OK and connects to the engine diagnostics fine but won't connect to anything else.
Is there anything else I need to do? I've tried various versions of FES / MES and 3 different laptops running xp, win7 and win 8.1 and they all do the same.
