corripeter
Folks,
After 2 years of relatively pain free Croma-ing.....My classic Italian Stallion, has bowled me two new curve balls.
Firstly ignition Switch rebuild woes, see my other topic.....and also it would appear that my Clutch Master Cylinder is not really generating any significant pressure now.
I am okay with the part replacement exercise, however the baffling bit is how do I get the Clutch hydraulic reservior section on top the brake master cylinder to refill?
I have read others mentioning the relationship between the brake pedal actuation and fluid moving into the clutch section of the reservoir....mine does not seem to do this......I can bleed fluid out the clutch elbow bleed nipple easily but the reservoir does not seem to replenish correctly...( The car is a 2005 1.9 16V Multijet)
So if any kind soul has been through the exercise of replacing the clutch master cylinder, I would interested to hear how you managed to get it to refill.
Thanks,
Peter.
Thanks,
Peter.
