Having, over the last year, replaced the alternator, bananna arms and thermostat I've learned that not much is simple to do on the Croma !
I now need to replace the rear springs and would appreciate advice on the "easiest" way from anyone who has done them already. Looks quite tight for using spring compressors ? Don't suppose just disconnecting shock will let allow enough clearance ? Thanks.
