tarquin1867
Member
The process goes on
While your having a go at blanking off the EGR , about a couple of inches away from the EGR is the Intake manifold pressure /temperature sensor . Take it out and clean it -just undo the single screw and disconnect the wiring plug (be careful not to lose the screw down the back of the engine. When I did mine it came out looking like it had a black afro haircut!! cleaned it with WD40spray and a bit of GENTLE prodding /poking. The difference it made to the running of the car was .
This was due to the fact that it "provides info to the ECU to set the VGT actuator and therefore the turbo pressure, to optimise engine operation and to adjust INJECTION TIMING"
Taken directly from the Fiat training outline.
As I said try the cheap jobs first
