Hello,
I got "Check engine" light and got the code P2002. So my DPF was clogged and I put some DPF cleaner to the fuel tank. I drove a few miles and also got "Check diesel fuel filter". I kept driving at high RPM:s and eventually got rid of the P2002 error, but the car still tells about the problem with fuel filter.
The diesel fuel filter was changed a bit before any of these problems so I really think the DPF cleaner did something. Do i need to change the filter again or can I clean the sensor or is it somehow possible to reset the fuel filter warning? I don't get any error codes for the filter. I'm using some cheap ODB reader and the software called "Torque". Can I get more information about this with a correct reader and multiecuscan?
Or should I just try some fuel additive for cleaning the fuel filter after using DPF cleaner
E: Oh, and the car is Croma -07 with 1.9JTD Multijet
