Thread Tools
Old 19-05-2013   #1
Croma 1.9 mjet springs
Posting this for info for anyone who needs to get new standard spring on a budget .
Had two springs brake last week ( one front and one back)
So out came the tools
Googled them and found out that the front are the same as a vectra c 1.9cdti
So no probs there.
Front. Kyb RH2661. 18 each.
The rear on the other hand are unique to the croma axle weight 1030kg
Kyb RH6388 69 each.
So did a bit googling
Vectra c 1.9 cdti hatchback. Rear axle weight. 960kg. (To soft)
Vectra c 1.9 cdti estate. Rear axle weight. 1230kg (to hard)
Signum 1.9 cdti 03-08 plate. Rear axle weight. 1130 kg (closest match)
As I have a tow bar fitted I figured it weights about 50-60ish kg so the signum ones would be about right
Priced them up and there were only 30 each
So fitted.
Kyb. RH2661 on front 18. Vectra croma ones
Kyb RJ6217 on rear 30. Signum. Ones
Kyb catalogue http://www.kyb-europe.com/pdf/2013-c...gs.pdf#page151
Car sits and drives fine and iam happy .will try and post pic .
Hope this help someone in the future
Croma 1.9 mjet
Bravo 1.2 16v sx
wot4y is offline Reply With Quote Quote
Old 19-05-2013   #2
Re: Croma 1.9 mjet springs
Excellent post. Thank you
Panda 4x4
Saab 9-5 estate
Mercedes E220 Cabrio
Lancia Thesis
lanciaman is offline Reply With Quote Quote
Old 04-08-2017   #3
Luxembourg
I know that passed a lot of time since this post, but i have same problem now...
Need pair of rear spring for Croma, 1.9Mjet 2007. In Fiat service asking me 272euro for pair. Its seems to expensive. I live in Luxembourg not so log ago, so i still dont know where i can search for on other side... Aditional problem makes cos everything is on French language which i still didnt learned well that i can google on french...
My question is can anyone help me like leave a link or something similar where i can order springs.
Aladin Drazanin is offline Reply With Quote Quote
Old 04-08-2017   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Aladin Drazanin View Post
Search on ebay for Kyb RH2661 and Kyb RJ6217
On ebay.co.uk there are multiple suppliers.
Robert G8RPI.
g8rpi is online now Reply With Quote Quote
Old 06-08-2017   #5
s130 has donated!
I replaced my Croma's springs with:
Kilen P/N:12168 (on box) / 78333 (on spring) / 7394410102533 (next to bar code)
Kilen P/N:52132 (on box) / 78347 (on spring) / 7394410102670 (next to bar code)
So much better and stronger than the original springs.
Fiat original springs are made from "tapered wire" coil diameter and fail on the thinner coil spring diameter.
The referenced Kilen springs (and some other after market OEM replacements) use a continual same diameter spring coil wire.
Spring wire tapering gives a softer/smoother response for small loadings and firmer response for higher loadings. THE BIG downside is that they are known to fail and always at the weakest point which is always at the thinnest coil wire diameter.
You could call this manufacturer's smoke and mirrors attempts to give the best ride in new cars (being evaluated by the press) and once all done and out of warranty we don't give a "monkeys"!. All carefully designed and crafted!!!!!
s130 is offline Reply With Quote Quote
Thread Tools
(T) Croma springs kennethgordon Croma 84 18-06-2012 12:34
Croma 599 starting price CROMA ELEGANZA MJET JTD150 dave Auction Watch 0 07-05-2011 23:45
(T) changing springs on 1.9 mjet matty seasider Grande Punto 1 14-05-2010 15:13
(T) 1.6 MJet lowering springs lonepilgrim Grande Punto 4 20-02-2010 20:30
(T) Croma springs fjaerhaug X1/9 2 14-05-2009 11:48
