Lamps by Post - For all your lighting needs
Thread Tools
Old 10-02-2012   #1
Renault Espace 3.5 V6
halilson's Avatar
halilson has donated!
P0238 - Turbo pressure fault
Hi, problem no 2! The other day while overtaking on a duel carriageway, the car 'hiccuped' and the check engine light came on. The car drove perfectly for the rest of the journey (approx 150 miles) and for the next few days until I had a chance to plug it into my laptop. The stored faults were egr - insufficient flow and a turbo pressure fault. As it was the first time I had checked the faults I cleared them to see which one would come back. I put a heavy duty cleaner in and checked the egr was functioning correctly, which it was. Last night, still with no new fault codes after approx 100 miles, I thought I would give it a blast to see what happened. The light came back on again, this time without any symptoms. When I plugged it in fault code P0238 - Turbo pressure came up. This covers such a wide range of faults from loose pipe to turbo on it's way out. Has anyone got any ideas of the best place to start? I had planned to clean the egr and fit a bullet plate (as recommended on the Alfa forum) but think my time could be better spent for now. I look forward to your comments.
halilson is offline Reply With Quote Quote
Old 10-02-2012   #2
PaulD78 has donated!
Re: P0238 - Turbo pressure fault
Search Forum for overboost problems. Then check vacuum pipes to overboost valve (Causes overboosting of the turbo).
Regards
Paul D
PaulD78 is offline Reply With Quote Quote
Old 10-02-2012   #3
Two potentially useful threads:
http://www.fiatforum.com/croma/23917...cuit-high.html
and
http://www.fiatforum.com/croma/24128...s-problem.html
Reckon it might be something similar.
Hope this helps.
DoIDon'tI is offline Reply With Quote Quote
Old 10-02-2012   #4
halilson's Avatar
Thanx for the quick replies guys. I will set about checking pipes and cleaning valves and sensors over the next week and keep you updated. Most of the posts on here have associated symptoms, or go into limp home mode, whereas fortunately I just have the warning light. I hope this means it's something simple.
Old 01-03-2012   #5
halilson's Avatar
Smile Re: P0238 - Turbo pressure fault
Update: Map sensor cleaned (which was completely blocked), new egr valve and bullet plate fitted and finally boost vacuum hose repaired (thank you doIdontI). Result: A very quick Croma with no more error messages! Now I can set about sorting the 'gear selector body' fault. Never a dull moment with FIAT ownership
Thread Tools
(T) P0238 moonman5 Bravo 6 02-07-2010 19:37
(T) Pressure Sensor Fault??? mouratos1a Bravo / Brava 1 11-12-2009 14:49
(T) P0238 Fault Code: Suggestions for Remedy? regandavies Panda 4 07-05-2009 01:00
(T) Turbo Pressure Fault (overboost valve?) cook66 Stilo 2 27-05-2008 08:40
fault code stored po106 / turbo pressure plausibility revszilard Lets Talk FIAT 1 21-05-2008 11:27
