Technical P0340+p0482+p0683
Does this look like your knackered one?
I know its used, but with 60 day warranty and based on the last bit of your Valeo part number (and the fact that this link says it fits a 1.8 vectra), I'd give this bloke a £15 best offer ;)
http://www.ebay.co.uk/itm/VAUXHALL-VECTRA-C-RADIATOR-FAN-CONTROL-UNIT-1-8-PETROL-Z18XER-VALEO-1379151-/141243968677?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20e2cbeca5
Might get you going before you can source a new one?
... my mechanic tells me the part no is PA6GF30 1379151 is this your part, if so where did you get one from ...
See #10
The one supplied was the one indicated in #10 & correct for a 55 1.9/16v150 Prestigio c/w twin fans – auto & other models may differ!
241830Z
Searching the valeo number you noted further (1379151) found this link which also implies that its the same as fitted to the Saab 9.3....
http://www.bildelsbasen.se/?link=list&searchmode=3&query=41835
That lists the actual GM number (24418356 - which is also used by Saab).
Searching on that gives a brand new one with a "make offer" facility...
http://www.ebay.co.uk/itm/121182643704?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
you can magnify the photo on that one to further compare.
Of course, you could just phone a FIAT main dealer and ask how much part number 71746359 :D
Hope thats of some help.
Hi thank you, i got one from vaux parts, I needed the plug and a bit of lead to, as the plug was coroded, but all sorted now APART from the engine management light is still on even tho its been repaired and its working ok, is there a way to reboot the computer to make it go off ?
