For a while we were getting occasional weird noises - a loud, ringing KLONG noise now and then from bumps in the road. Finally it got to the point where just shutting the door would make it go DONG.
I found the cause, and the solution is very simple. There's a shiny heatshield that sits above the exhaust. It's made of very thin metal and is held on by eight M6 nuts onto threaded posts. Try hitting it and see if it rings. If so then it's loose.
The nuts are those that have a washer built in. Only 3 out of 8 were actually holding (just) - on the rest, the metal had vanished from under the nut. I can only assume some kind of reaction had occurred, as there was no rust but a clean hole neatly cut out where the nut was pressing.
I bought a pack of repair washers from B&Q for £1.98 and put one under each nut. Works a treat, good as new. These are actually zinc plated, which should last as long as the car. Stainless ones may be better if you can find them.
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9708657&fh_view_size=10&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=repair+washer&fh_eds=%c3%9f&fh_refview=search&isSearch=true
EAN: 5020789859199
These are actually M8 washers, as I had them already. M6 ones are also available. However, the little bit of slack was a benefit, as these only just fit and it's useful to be able to waggle around the neighbouring raised parts. There's no risk of the wide nuts popping through the 8mm hole.
EAN: 5020789859199
