Thread Tools
Old 15-02-2011   #1
Re: Buying a Croma in the morning
What should you look / check for when viewing and test driving?
service history
condition bodywork, interior, engine bay, kerbed wheels?
mileage
close all windows, turn off radio / CD and fan, drive on a rough road, listen for suspicious noise and feel for a supple ride
no black smoke from the exhaust when accelerating strongly from low speed
pickup is smooth at light throttle
all inside and outside door handles work OK
check that the hatch / tailgate / boot lock and release works OK using both the (micro)switch / handle on the hatch and the key fob
no messages on the dash LCD
no dashboard warning lights
all windows work
glove box lid opens and closes OK
all recalls and software updates have been done
there are 2 key fobs with the car
Thanks dave thanked for this post
uksdsgl is offline Reply With Quote Quote
Old 19-03-2011   #2
The orginal 'Old Grumpy'
Radlet6's Avatar
Radlet6 has donated!
Re: Buying advice for a Croma
For Diesel cars (vast majority) also check service history: ensure cam belt changed at 5 years or 60,000 miles and that water pump and tensioner changed at the same time. If no record, factor in 300 to have it done.
Check also if the alternator has been replaced recently. If it has been on the car for over three years there is every likelihood that it will fail soon. Factor in another 250 (the alternator alone is 200).
If the car is sluggish in pulling away but picks up at above 2,000 rpm (a bit like turbo lag) it is likely the EGR valve is sticking. 10 minute job to replace but valves are around 120. The other possibility is a split in the turbo hose (very small beer).
The auto box is virtually indestructible, but the manuals have been known to turn to papermache at high miles. New box is 1500 but they can be rebuilt for less than half that.
If you can get the car in the air, or the wheels off. Check for broken springs and excessive play in the CV joints at the gearbox. A spring will cost around 160 to replace at a dealer. CV joints considerably more.
AS part of the Government's new austerity measures, the light at the end of the tunnel has been turned off indefinitely.
Radlet6 is offline Reply With Quote Quote
Old 28-09-2011   #3
Now that wife has returned to her second Croma, this one being one of the last. 2 other concerns not listed.
Drive shaft Rumble which equals vibration in steering colum.
EGR valves same as GM, 50 notes cover it.
2014 Lancia Ypsilon S-Series.
1999 Fiat Coupe 20VT.
FiatFleetFamily is offline Reply With Quote Quote
Old 25-02-2014   #4
Radlet6's Avatar
I want to amend my last reply. In answer to the question 'When buying a Croma what should you look for?'
I would answer an effin Audi. At least they fleece you up front. :-)
Old 21-02-2015   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Radlet6 View Post
I would not be so sure about that. The typical hourly labour rate for an Audi Dealer is twice that of a Fiat one!
Yes, I used to own an Audi.
g8rpi is offline Reply With Quote Quote
Old 24-09-2015   #6
Belgium
I am as follow up for my Lancia Lybra, very happy with my Croma JTD 1.9 multijet from 2008. But I am looking for one of the lest build, a 2011 JTD!? Have the last build daylight running lights?
NDC is offline Reply With Quote Quote
Thread Tools
(T) Croma Autobox Oil level advice please! DoIDon'tI Croma 5 19-05-2011 18:22
(G) Buying a Croma in the morning Fiatcromahull Croma 32 18-02-2011 22:19
(G) First Panda 4x4 buying advice needed, newbie advice needed!! BenMK4x4 Panda (Classic) 19 04-06-2009 19:33
Am I Insane ...thinking of buying a Croma!! Angryeyes Lets Talk FIAT 77 08-07-2008 21:01
