Has anyone gone for winter tyres?
What vauxhall/Alfa wheels would fit a 150 multijet Croma?
Not the Alfa 166. It's 5 x 100....Astra H, Signum, Saab 93, Alfa 166 & Brera wheels too.
my mistake, but one of the number ones fits for sure most likely the 159...159 instead?
159/Brera share the same GM 5x110mm PCD as the Croma.
The 166 is 5x108mm PCD.
I’m sure some have fitted Alfa wheels on their Croma – there was an Alfa set (5-horseshoe style) in Classifieds only few weeks back … DIDI?
Any problems? For example – should you want to downsize from 18” to (say) 17” then Alfa 17” are (I believe?) 7.5Jx17 (& not 7Jx17 as standard for Croma).
55 Prestigio 1.9/16v 150HP 7.5Jx18ET41 225/45-18
Still not sure to be honest.Is the Mito 4x98 or 4x100
How about the Gulietta, is that back to the traditional Alfa 5 bolt?
The 1.9 150 and 2.4 have truck brakes (or they seem to!) so you need minimum 16" wheels.
As you drop a rim size you need to drop the width and increase the sidewall percentage. This means the reduction in rim width (J) should not be a problem. You might need some spacers to increase the offset - this depends on the clearances with the suspension and steering.
225/45R18
205/55R17
195/65R16
Then the 166 wheels fit as well, it's only 2mm across 2 holes less than 1mm difference.159/Brera share the same GM 5x110mm PCD as the Croma.
yes, i have a set myselfdo the 16" vauxhall steel wheels fit over the big brakes on a 150 jtd auto?
