Hi Folks,
Have been having on and off issues with my power steering (quite literally!) whereby most of the time it's fine but now and again during slow speed manouvres - out of junctions or joining roundabouts etc. - I lose all power steering and can barely turn the car.
Very alarming when it happens so when it originally happened a few months back, the first thing I did was check the power steering fluid level - found it was very empty so topped it up to full. The fault then stopped happening for a couple of months 'til recently when it's happened again a few times.
I needed the car serviced so put it into my usual local garage and also asked them to fit some ARB bushes I'd sourced (to elimate 'that' creak in damp conditions) and check out / top up the power steering fluid whilst they were at it.
The service got done and they reported that the power steering rack needed replaced as it was leaking and the reason for fluid consumption and the intermittent fault as described. Cue them trying to source the part, no luck through the local motor factors so resorted to Fiat who then took a couple of days to come back with £500 odd + VAT for a reconditioned rack or £800 odd + VAT for a brand new one. Garage reckons around £150 labour to fit on top.
Meanwhile I'd been hunting around for a GM part knowing much of the chasis / suspension / steering is actually GM and in common with the Vectra-C & Signum. I've seen listings on ebay for Vectra-C power steering racks from £110 - £250, all a damned sight cheaper than what Fiat are quoting but as there are a number of different racks available am unsure which one to order up. Can anyone help here with a GM equivalent part number to what is on our Croma's? Mine is a 1.9 JTD 8v 120bhp 'Dynamic' model on a '55 plate.
I searched this forum looking for others with rack issues and couldn't find anything - only P/S pumps failing which did make me wonder if the diagnosis by the garage is correct but also checked Vauxhall forums and found a multitude of rack failures on the Vectra-C and Signum so sounds plausible.
All help much appreciated - have instructed the garage to top up the fluid for now whilst I source the correct rack rather than bending over for Fiat.
I'm also told I have another leak coming from the N/S gearbox->driveshaft oil seal - anyone else had this one? Fiat quoted £19 + VAT for the seal so got them to order it up, couple of days to get in and I need the car for a long trip so holding off on this and the rack getting replaced 'til after thinking I should be OK given both are only slight leaks.
The ARB bushes themselves were an adventure with Fiat supplying the wrong part (too small) then stating that was the only part available. I had to get the GM part number stamped on the worn bushes from the garage then run round to the local Vauxhall garage for them who had them in stock and at half the price of Fiat funnily enough...
Cheers,
Brian.
Cheers,
Brian.
