kadee
I have downloaded the elearn manual for my Croma and used winrar to open it up but it's asking for a user name and password. How do you get past this?
Hi all
I've just installed the Croma eLearn but I'm having issue using it.
As u can see by the attached picture none of the buttons both on the left sidebar and on the top bar are showed.
Tryied uninstalling and reinstalling it again but no luck.
Any suggestion?
WinXP
btw I cannot find the eLearn ISO link in the download section. Has it been removed?
And that is the problem.There aren't supposed to be any buttons at the top. Set which language and engine size you want from the drop down menus on the left then click on the car picture. You should then be able to select the year range
Ok, that's the first thing I checked.Does it use your installed web browser? (it may do, even if it doesn't look like it, via ActiveX controls or similar). Perhaps you have an ancient version of Internet Exploder, or Firefox instead of it or something.
Dear DooferIs someone still after eLearn? I'll provide a link if required.
