DoIDon'tI
Member
- Feb 17, 2008
- 470
- 81
Not agreeing with the modern trend of several car manufacturers specifying that the Automatic Gearbox oil never needs changing, I recently changed the oil on my car. I followed the procedure on Elearn but it's a little vague in that it doesn't actually specify whether the engine is running when the level is checked (i.e. it never tells you to turn the engine off).
So;
Perhaps someone can clarify this:-
Should the engine be running when the ATF level is checked, and;
Should the gearbox oil be warm?
Your help would be appreciated, thanks.:worship:
So;
