Thread Tools
Old 03-10-2012   #76
Re: What really is GM on the Croma????
Quote Originally Posted by s130 View Post
Maybe GM sold the dregs of their crap stock to Fiat when both companies signed their colaboration deals. Sadly GM got the Fiat diesel engines/technology and Fiat got things they were not bargening on.
And Saab got it all for free..and still could no make any money before going bankrupt.
Saab 9-5's and 9-3's have many parts with a Fiat and GM embossing on!
2014 Lancia Ypsilon S-Series.
1999 Fiat Coupe 20VT.
FiatFleetFamily is offline Reply With Quote Quote
Old 03-10-2012   #77
Trader Rating: 10
dave has donated!
Quote Originally Posted by FiatFleetFamily View Post
saab donated the key in the wrong place bit
What is right is not always popular and what is popular is not always right.
Albert Einstein.
Old 17-11-2012   #78
Trader Rating: 10
dave has donated!
Albert Einstein.
Old 17-11-2012   #79
s130 has donated!
Only way to be sure is to look at those links, note all part numbers, OEM equivalents etc. and then start from there.
Example. Look at Kilen / other OEM springs for Croma's and then check if same parts are also listed for Vectra C.
Bearing in mind there will be 10s of thousands more Vectra/Signum than Cromas were ever made then most of these sports kits will always name/target the biggest market.
s130 is offline Reply With Quote Quote
Old 07-03-2014   #80
Trader Rating: 10
dave has donated!
GM part number for 1.9 16v sump plug is 55588255 cost 9 but the cheap ebay one i got 2 changes ago snapped yesterday.
Albert Einstein.
Old 15-04-2014   #81
Norway
Quote Originally Posted by Hellcat View Post
Nothing wrong with that! Any brakes should be fine, if you spend a lot more perhaps you won't have brake fade as quickly if you drive it hard.
Just had to get something around the ABS system replaced on ours. It's a GM part and means a bit chunk of the wheel needs to be replaced. Will have to find out in more detail what part has broken.
Can anyone confirm this? I need to change a rear ABS sensor, and have found one for Vectra C.
mzziaz is offline Reply With Quote Quote
Old 15-04-2014   #82
Trader Rating: 10
dave has donated!
Quote Originally Posted by mzziaz View Post
it should come with a hub
Albert Einstein.
Old 15-04-2014   #83
Norway
Quote Originally Posted by dave View Post
It does.
Old 15-04-2014   #84
Trader Rating: 10
dave has donated!
when i bought mine it said fits croma and vectra on the ebay listing
edit paypal recipt says this
VAUXHALL SIGNUM 1.9 CDTI 16V 110KW 04-05 REAR WHEEL BEARING HUB KIT + ABS
Item Number 251044891662
Albert Einstein.
Old 15-04-2014   #85
Norway
Ok, guess it is the same thing, then. I can't imagine they have different systems for Vectra and Signum.
Thanks, Dave.
A noob question: there is no difference between left and right, is there?
Old 15-04-2014   #86
Trader Rating: 10
dave has donated!
no,
if you put 251044891662 into ebay search the listings shows all the info on what cars they fit
Albert Einstein.
Old 01-02-2016   #87
Quote Originally Posted by DoIDon'tI View Post
Sorry chaps, the 159 has the 'premium' platform as opposed to the 'Epsilon' one fitted to the others (look at the front suspension and you'll see what I mean). The 'premium floorpan is also the base for the new Vauxhall Insignia BTW. The later Saab 9-3s do indeed use the 'Epsilon', however the closest car(s) to the Croma is the Signum/Vectra C estate (due to the axle weights). Some fluid reservoirs are also GM marked, I wouldn't bet against many of the electrical components being common either. The petrol Cromas use a GM engine, but the Multijets are Fiat. Haven't found any other bits yet but am willing to look if anyone's that curious?
HTH.
Gearbox on my petrol Croma is GM along with the engine, and lots of engine ancillary bits too
johndavidneville is offline Reply With Quote Quote
Thread Tools
(G) Wiper arms for a Croma 86>92 model, anyone selling/ breaking a Croma? pietch Croma (Classic) 1 20-03-2008 19:52
