Thread Tools
Old 29-04-2009   #31
Re: What really is GM on the Croma????
All Vectra C and Signum, but you need one for the appropriate axle weight. Vectra C springs are notorious for breaking..!
DoIDon'tI is offline Reply With Quote Quote
Old 07-05-2009   #32
Quote Originally Posted by mangolusso View Post
Hi Hellcat, It is the 150 with the 305mm front discs. I have been quoted 291 inc vat for non OEM & at the same garage 365 inc vat for OEM.
Fiat want 340...
Mango
Try brakepartsuperstore.co.uk
2014 Lancia Ypsilon S-Series.
1999 Fiat Coupe 20VT.
FiatFleetFamily is offline Reply With Quote Quote
Old 13-05-2009   #33
Thanks for the reply DoIdon'ti
being a bit thick when it comes to cars how do I know the axle weight. When I look at the parts for thr vectra c (Sigrum) it just comes back with one part No.
it seems that fiat dont keep any parts for thr Croma 2 in the Uk and when it comes to suspension parts none are held by fiat in Italy they rely on the suppliers, so if we want to keep these Cromas running we need to start talking GM parts numbers to each other, I have traced brake part Nos and will post them on the Thread in the near future. Because my croma is being repaired under warranty I have to wait for the part to arrive through the Fiat system. My car has now been off the road since 24th April.
regards chrisgolfpar
chrisgolfpar is offline Reply With Quote Quote
Old 13-05-2009   #34
The axle weights are on a plate fixed to the front structure of the car, under the bonnet - they're also in the owner's manual in the 'specifications' section. If you search for "axle weights" on www.vectra-c.com then I believe that should clarify things. If all else fails then get suspension bits for a 3-litre diesel Signum and you won't be far off. There's often someone on the Vectra forum selling springs as they often get swapped for Eibach lowered and stiffened ones.
HTH.
Thanks Hellcat thanked for this post
Old 13-05-2009   #35
Thank you DoIDON'TI from chrisgolfpar
Old 14-05-2009   #36
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Quote Originally Posted by chrisgolfpar View Post
You know you can click the under his post to thank him
Thanks chrisgolfpar thanked for this post
Drives: Alfa 147 Lusso , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 05-12-2009   #37
My clutch has just gone on my croma 1.9 8v. Is there a gm cluch that can replace it.
chrisgolf par
Old 05-12-2009   #38
MiTo 155
alexh365's Avatar
Trader Rating: 2
alexh365 has donated!
chrisgolf par
Likely to be the exact same valeo (or equiv) part just re-boxed for FIAT / GM.
Ittl also depend on Flywheels and Gearboxes to get the correct part.
alexh365 is offline Reply With Quote Quote
Old 06-12-2009   #39
A quick search on eper for the part number (55195392) then putting that in Google says that this part number is shared with the Alfa 159 and should sell at approx 169. I'd advise caution because when I've searched for other parts in the past on Google there have been GM alternatives listed by third-party manufacturers, but in the case there aren't.
Which doesn't mean there isn't a GM alternative - sorry I can't be more helpful! If you have the luxury of time then the specifications for this part are listed on the net, you could try taking them into a motor factors and comparing them with the GM item?
HTH.
Old 06-12-2009   #40
MiTo 155
alexh365's Avatar
Trader Rating: 2
Quote Originally Posted by DoIDon'tI View Post
HTH.
The specs can be found in the Valeo online catalogue!
http://www.valeoservice.com/html/unitedkingdom/en/
Click "Valeo Web Catalog" at the top and then good luck
Old 08-12-2009   #41
HTH.
Thanks DoI Don't. I got lucky on this Found shop4parts on the net, they only deal in Fiat original spares and they seem to be able to do cross ref and you are correct the clutch on the Alfa 1.9 d is the same as the croma 1.9 8v multijet. I was also recommended by my garage to replace the thrust bearing and the slave cyl and this cross ref with the fiat punto grande. What worrys me is why a clutch plate sould break apart after only 44k, ther was no warning like it slipping it just went.
Fiat quoted 675.0 to do the work, I dont't think my local garage is going to be much cheaper. The parts cost 303.0
Old 08-12-2009   #42
Post scratched
s130 is offline Reply With Quote Quote
Old 08-12-2009   #43
Quote Originally Posted by s130 View Post
Post scratched
Are you 'feline' OK Nick? That's a strange habit.
Old 09-12-2009   #44
Was a bad night, and tonight is not much better. I was obviously writing / spouting complete rubbish so decided to pull/scratch what I wrote.
Old 10-10-2010   #45
I need front brake discs and may have to buy a steering rack for my 2005-55 1.9 16V diesel.
Do you know if there are identical Vauxhall or Saab front brake discs or steering rack?
Or can you recommend cheaper and / or better brands?
Thanks in anticipation.
uksdsgl is offline Reply With Quote Quote
Thread Tools
(G) Wiper arms for a Croma 86>92 model, anyone selling/ breaking a Croma? pietch Croma (Classic) 1 20-03-2008 19:52
