Hi all.
I wonder if anyone out there can shed any light on the small problem I have with my '92 2.0 turbo ie Croma [8valve] ?
It has an intermitant starting problem in that it will just spin over on the starter and not fire, it will do this 4 to 5 times and other times it will fire straight away, it idles lumpy, say on three cylinders once fired regardless. Once warm it's fine.
The car will do this hot or cold.
It is standard apart from a K+N cone filter and dump valve, plugs, leads, dizzy cap and rotor arm are all new. I have also replaced the water temp sender.
