| 1st -> 2nd handbrake warning light?? hey guys my mates mum has just aquired a broom yellow cinq unsure of the year but she says that when changing from 1st gear to 2nd the handbrake warning light (low fluid level warning light) comes on does anybody have any ideas? as im under the impression that they are cable operated clutches and rod linkage gear selection.cheers Stain
__________________ Rich (Stain) Out of the Crate Black Cinq Sporting WIP:- "Tappet" Noise, G/box oil change, inner cv boots, outer cv joints, Rear Bumper Insecure, Towbar Install, Handsfree Kit and Speaker Install | |||
| | #3 | ||
| custodian of imola blue | Re: 1st -> 2nd handbrake warning light?? As above -- sounds like acceleration is causing the (little) fluid in there to wobble the float, if you see what I mean, and your mates mum obviously gasses it hard from the lights........... I've had this on a Sei, and here the mesh of an after market filter had partially nibbled through the insulation on the harness, but the above seems much more likely.
| | #4 | ||
| Re: 1st -> 2nd handbrake warning light?? job done boys low as fook fluid level thx for the advice
| | #5 | ||
| mad bad and very very old | Re: 1st -> 2nd handbrake warning light??
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #6 | ||
| Re: 1st -> 2nd handbrake warning light?? will do thx man
| | dcmo | Marea | 10 | 24-03-2008 15:00 |
| | kayone | Punto | 14 | 12-01-2007 20:11 |
| Warning light and boot light | Boanerges | Panda (New) | 48 | 23-05-2006 15:25 |
| Blinking handbrake light | Sparrow | Panda (Classic) | 5 | 23-04-2004 03:19 |
| | Grav | Bravo / Brava | 3 | 23-02-2004 14:56 |
