| tricky rick | heater my missus sei heater does heat the car even when hot
| RIP L181 VBB | Re: heater what? If you are saying the heater is a bit iffy then it could be a number of things. Could be fuse related for example. Also there are a number of things you can check, such as the water pump could have had it. Could check the heating system, may need flushing. Your 'cock' could have also bitten the dust. This regulates the temperature in a sei as we dont have a gauge Scrappie or new for one of thoseA few suggestions for you
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | ||
| | #3 | ||
| tricky rick | Re: heater had new radiator fitted got flushed out then where is the fuse you are talking about and which one is it ill start there any help would be great
| | #4 | ||
| Re: heater Just blown the fuse for the heater on my sei. The fuse box is on the drivers side and there is a diagram showing wat all the fuses are for on the cover. Check this for further details: http://www.fiatforum.com/cinq-sei-te...77-heater.html Cheers Ginner
| | #5 | ||
| tricky rick | Re: heater fan works fine just does not get hot
| | #6 | ||
| i am | Re: heater could be the 'cock' is jammed or an airlock. the sei has a stopcock to adjust the coolant flow to the heater matrix when you adjust the heater dial. if this is seized it doesnt move to allow hot coolant through. | ||
| | #7 | ||
| tricky rick | Re: heater the heater dial seems fine i can feel its not seized ckecked for airlock seems clear the 2 pipes at the bulkhead they are both get hot aswell
| | #8 | ||
| tricky rick | Re: heater where will i find the stopcock is it behind all the controls
| heater not working. cant find the problem,. | Xsisley | Panda (Classic) | 2 | 13-01-2007 22:28 |
| | A1ex | Bravo / Brava | 2 | 11-01-2007 05:54 |
| | QuickNick | Bravo / Brava | 0 | 03-07-2006 09:52 |
| | superleccy | Stilo | 19 | 29-08-2005 13:31 |
| | CWpete | Punto | 7 | 12-07-2004 05:35 |
