Going off the thread topic a bit, but it seems finished, and you lot can surely give me some answers and ideas. Here's hoping your all subscribed
As I'm sure you know I have put the 1.2 16v engine into the Sei. I have the Super Sprint Punto 1.2/1.4 16v manifold, which has a flange at its base.
I need an exhaust system fitted for here on right to te end of the car.
The standard bore of the Sei sporting is ~32mm or 1.25 inches. I am bodging this on now, but it a VERY temp fix.
I was looking at a custom system made up, ~300 without a cat, 500 with, so i went hunting for cheaper alternatives.
Now, looking at the Super Sprint stuff, there is a decat section, that runs flanged from the manifold and on the site they specify a diameter of 44mm, ie. 1.75 inch. If its good enough for emma's 1.4 is good enough for mine
If i get the 1.75 inch decat though, i will obviously get the back box as well. However, is this part standard Sei diameter of 1.25"?? It doesn't mention any diameter on teh site
If it's 1.25" I'll have to rethink and go custom, but if it is 1.75" throughout, i can get the decat and back box for about 170 delivered, a significant saving over a custom system
If you could just confirm your diameters and any thoughts on my plan that would be great
I am prepared to do little cutting, as the 16v manifold may be in a slightly different position, but otherwise, it should hopefully be a straight fit
Cheers for your ideas
Kristian
