The FIAT Forum
Old 18-03-2007   #1
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
levemir has donated! United Kingdom
Question rear bush removal tips
hi there people
I am going to be replacing my cinq rear bushes in the next week or so, so I am after any tips any of you may have to ease removal .. and refitting.
thanks
levemir is offline
Old 18-03-2007   #2
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
Re: rear bush removal tips
Length of studding, two very large sockets and you can then fairly easily wind out the rubber centres.
Then to remove the steel sleeves, hacksaw two slots (carefully) along the sleeve then knock them out with a hammer and drift.
Made that sound easy, but its a pig of a job to do. But you get faster after you've done one or two.
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
Old 18-03-2007   #3
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Alternatives are:
1. Burn the rubber out. The rest should come out more easily due to the heat. A blowtorch will do it -- no need to use the oxy-acetalyne gear!
2. Take them to an engineering shop: they should be able to press the whole lot out and press the new ones in.
Remember, there's a lot of stuff to remove before you get to the arms.I'd start with the WD40 and wire brush a couple of days before you start on the actual job.
fingers99 is offline
Old 18-03-2007   #4
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
I was planning on leaving the hub and drum attached to the arm, I can see that I have to undo brake pipe, and handbrake cable, then the shocker, lower the arm with a jack to release the spring, then off with the arm bolts.
Is the brake pipe, in general, easy to remove?
Extracting the bushes [or most of..] with a threaded bar seems a good idea, I reckon that with a drilled plate[s], I could even install them that way..
post away if theres any more tips!
thanks
levemir is offline
Old 18-03-2007   #5
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
start soaking the brake unions in pentrating oil, start now. keep putting plenty on. and often.
arc is offline
Old 18-03-2007   #6
umop apisdn
balidey's Avatar
Trader Rating: (1)
If you are putting Powerflex bushes in, these will push in by hand.
balidey is offline
Old 18-03-2007   #7
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Make sure you get the right spanners for the brake fittings....the LAST thing you want is to round one off! .. .or if ya poor, get a socket spanner and grind a bit out to fit over the tube...it may work
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is online now
Old 19-03-2007   #8
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
thanks
I have also noted this page: http://www.powerflex.co.uk/removal.asp
levemir is offline
Old 19-03-2007   #9
arc
arc's Avatar
Trader Rating: (0)
spanner only costs 3quid from halfords
arc is offline
Old 19-03-2007   #10
kritip's Avatar
Trader Rating: (3)
Not when I got mine from there more like £5-7 dependant on size. As the new hoses were not the same as fiat's, I needed 3 or 4 of them (can't recall exactly as I block painfull memories )!!
They were the Halford's Pro series, but couldn't see any cheaper ones else I would have snapped them up
Old 19-03-2007   #11
arc
arc's Avatar
Trader Rating: (0)
halfords pro, £3.49 - so says my receipt!
arc is offline
Old 26-03-2007   #12
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
Bushes Done!
Sad to say, no pics [to put a guide together], my other half knocked the camera off the cupboard, and it snapped the battery flap off, luckily [or not] it was a bit of a relic, but it did the job perfectly!! RIP
Anyway. Undoing the lower shocker was easy, even the brake pipe came off easy, handbrake cable removal fine too.
Dropped the arm, remove spring, undo arm, remove.
Getting the bushes out, pain in the backside!! I drilled out the rubber in 4 places on each bush, the centre tapped out easy. I was struggling to get the outer bush sleeve out, I tried with the hacksaw as suggested, it was peeing me off big time!! I tried with a cold chisel, a bit better, then I realised that the bush has a lip, I hit that with the chisel and hammer, and the sleeve flew out!! I was on a roll then!!
So, job done, took me about 4 hours to do one complete side, by myself.
levemir is offline
(T) Changing front suspension arm bushes(change to guide format) peaster2k Cinquecento / Seicento 2 21-02-2005 19:57
(T) Excessive Rear Tyre Wear pugwash Stilo 8 23-01-2005 16:30
(T) Removal Of Rear Seats PhatAshKi Cinquecento / Seicento 23 23-11-2004 21:21
(T) rear door window crank removal newportz Punto 10 18-02-2004 05:00
