The FIAT Forum
Old 14-04-2004   #1
Trader Rating: (0)
Funny noises
My Cinqy is making funny noises in 1st and reverse, sounds like something is being chewed up!
Looked at the sticky and it seems that it could be the rear engine/gearbox mount. How easy is it to replace, I have no real knowledge of cars and it took me ages to fit a clutch cable!
Has anyone done any guides for this? Will I find it in my Haynes manual and how can I be sure it is the mount?
Sorry for all the questions, and thanks in advance.
Scott:)
ScottieCinq is offline
Old 15-04-2004   #2
Trader Rating: (0)
Any help would be appreciated.:D
Old 15-04-2004   #3
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
The 'usual' mount is the one on the nearside of the car, just under the passengers right foot, assuming your passenger has her feet on the floor, not the windscreen. (oops, mind running away again, must be my age)
The mount is fairly easily removed, but the car must be supported on axle stands. A trolley or bottle jack can be placed under the arm that attaches the mount to the powertrain, the mount loosened, then the jack let down a little to allow removal of the mount.
refitting is the reverse of removal.
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 15-04-2004   #4
Nothing's Impossible!
brickfoot's Avatar
Trader Rating: (0)
brickfoot has donated! United Kingdom
a new mount is about £10-12 from fiat;)
brickfoot is offline
Old 16-04-2004   #5
Trader Rating: (0)
Thanks guys, knew you wouldn't let me down:D
How do I know if it's definitely that? Will I definitely need ramps or can I just crawl underneath and do it that way?
Cheers,
Scott.
Old 16-04-2004   #6
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
Yu'll want to use ramps if yu not using them....its damn difficult to crawl past the 899cc sump!!
Tom (AofB)
GrpN Catback Exhaust system on...rattles like f**k, but very nice!!!
arseofbox is offline
Old 16-04-2004   #7
Trader Rating: (0)
I've got a sporting, so it's a 1100cc. Poo!! Is that the sort of thing a tyre place could do or is it a mechanic only job?
Old 16-04-2004   #8
brickfoot's Avatar
Trader Rating: (0)
Mechanic, it's easy to do as a diy job, as long as you can get under the car. 3 bolts to do and the mount is off;)
Old 16-04-2004   #9
Trader Rating: (0)
Cool, you make it sound so easy. If I go and buy some ramps, and use a Haynes manual am I going to be able to sort it? Is it going to look like it's split?
Old 16-04-2004   #10
brickfoot's Avatar
Trader Rating: (0)
that's how i did mine, ramps, haynes manual and a set of spanners:p
Old 16-04-2004   #11
Trader Rating: (0)
Will it cause any probs if I continue to drive it for a few weeks?
Old 16-04-2004   #12
brickfoot's Avatar
Trader Rating: (0)
Nah, as long as you don't race it like a boyracer then you should be fine:)
Old 19-04-2004   #13
Trader Rating: (0)
In order to do the job am I going to need a trolley jack or will I get away with ramps and spanners?
Thanks.
Old 20-04-2004   #14
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
be careful with ramps, on both my abarth kitted and non kitted cinqi's i was scraping the bumper quite badly on ramps
GhostWKD is offline
Old 20-04-2004   #15
brickfoot's Avatar
Trader Rating: (0)
ramps and spanners are fine, if you've got an abarth kit on as ghost suggests then place a couple of wood blocks in front of the ramps to drive up onto beforehand.
If you're using a trolley jack, make sure you use some axle stands too, never trust a jack on it's own when you're working under a car
(G) funny sound at front of car Genie Punto 2 24-07-2004 21:57
(T) funny sound at front of car Genie Punto 2 30-06-2004 02:08
(G) Funny noises from my Uno 1.0 ie start The Negotiator Uno 4 19-04-2004 15:42
(T) Funny noises neilfreshwater Punto 0 10-01-2004 19:15
(T) Funny noises fixitagaintomorrow Cinquecento / Seicento 0 11-06-2003 04:07
