| Temp gauge not working Temp gauge does not move. Earth sender wire & gauge reads max. Is this a gauge fault?
| i am |
| | #3 | ||
| this is where i stand | hope u have more luck with this than i did, mine did exactly the same (1995 Cinq Sporting), getting a new sender unit should be a very easy job (around 8quid) but for some reason mine was 'different' and took ages for fiat to find the 'right' part.. and it still didnt work once i got it. when you order the new sender unit, make sure its the one for the gauge not the ECU. ECU one is rather more pricey. Cinq Sporting - and yes, its broom yellow!
| | #4 | ||
| mad bad and very very old | Sounds like a sender problem, and its certainly easier to change. Cheers D Grumpy old git going fast downhill rather than downhill fast!!
| | BR1AN | Punto | 1 | 22-02-2004 20:04 |
| Temp gauge | voorhas | Panda (Classic) | 2 | 11-01-2004 02:58 |
| | CphFiat | Punto | 2 | 27-11-2003 19:13 |
| | CHARLIE-CINQ | Cinquecento / Seicento | 16 | 17-11-2003 18:09 |
| | Matts Dad | Punto | 18 | 10-09-2003 22:48 |
