| cinq power steering question Is it possible to convert cinq to power steering.
| custodian of imola blue | Re: cinq power steering question Possible, but wildly impractical. You'd need the speed sensor from a Sei gearbox, an MPI ECU (which would mean converting the engine to MPI), to convert to an electronic speedometer and digital mileometer, and then you'd still need the power column and motors. It'd be easy enough if someone gave you a tail ended Sei, but otherwise, forget it.
| | #3 | ||
| RIP L181 VBB | Re: cinq power steering question Pump your tyres up, will make the steering a bit lighter and better
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | ||
| | #4 | ||
| mad bad and very very old | Re: cinq power steering question Quite often old tyres can go a bit saggy in the sidewalls. If the tyres aren't new, fit new tyres, you'll be amazed at the difference. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
| Re: cinq power steering question I believe that the power steering has it's own ECU, so it only needs a signal when to assist and when not. This signal comes from the mpi ECU, so originally you need an mpi Sei, but i'm pretty sure that this signal is just a +12V when reaching 35mph (or so). It should be able to simulate it using a (punto type CITY) button. Once i get a used steering wheel ECU, i'll give it a test.
| | custard | Cinquecento / Seicento | 70 | 4 Days Ago 21:05 |
