- Reference : R/1997/080
- Manufacturer Ref :
- Make: FIAT
- Model : Cinquecento "S" "SX" and "SOLEIL"
- Launch Date : 24/11/1997
- Numbers Involved : 1090
- Build Start Date : 01/11/1996
- Build End Date : 30/04/1997
- Concern : POSSIBLE LOSS OF BRAKE SERVO ASSISTANCE
- Description : After extended high speed running, brake servo assistance may be lost due to petrol contamination of the servo diaphragm.
- Remedial Action : The affected vehicles are being recalled for replacement of the servo brake vacuum pipe and checking of the brake servo efficiency.
- Vehicle Id : ZFA17000000 862082 to ZFA17000000 957625
- Reference : R/1998/013
- Make: FIAT
- Model : Cinquecento (Non air bag)
- Launch Date : 23/02/1998
- Numbers Involved : 73
- Build Start Date : 01/11/1997
- Build End Date : 30/11/1997
- Concern : FRACTURE OF STEERING COLUMN WELD
- Description : As a result of a manufacturing fault the weld securing the steering column universal joint may fail.
- Remedial Action : Affected vehicles are being recalled for replacement of the steering column shafts with quality assured units.
- Vehicle Id : 1081337 to 1086344
- Reference : R/1999/071
- Manufacturer Ref : 2974
- Make: FIAT
- Launch Date : 18/10/1999
- Numbers Involved : 52612
- Build Start Date : 01/10/1992
- Build End Date : 30/07/1998
- Concern : POSSIBLE CORROSION OF FUEL TANK RESULTING IN FUEL LEAKAGE
- Description : On some Cinquecento vehicles it is possible the fuel tank may corrode at the centre seam, with a consequent risk of fuel leakage.
- Remedial Action : Replace the fuel tank with a quality assured unit
- Vehicle Id : 064047 to 1166832
