The FIAT Forum
Old 10-02-2007   #1
Trader Rating: (0)
heating stuck
Hello,
looks like I ended up at a bad garage. Right after the last service the heating of my little Seicento stopped working. Well, it's still working but the heating doesn't go off anymore. I can only chose between a medium (now standard) and higher temperature I complained at the garage but they claimed to have nothing to do with it, I'll thus have to pay for the repair.
Can I fix the problem myself? How is the heating controll of a Sei constructed? I'm glad about any technical advice
tethys
tethys is offline
Old 10-02-2007   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: heating stuck
What did they do at the service?
Do I get you right -- the blower works fine, but you always get hot air?
fingers99 is offline
Old 10-02-2007   #3
Trader Rating: (0)
Re: heating stuck
Yes, I suppose that's what I mean. I cannot switch off the radiator anymore. I can still switch off the blower but then the radiator is still working of course. There must be something wrong with the thermostat.
Tethys
tethys is offline
Old 10-02-2007   #4
fingers99's Avatar
Trader Rating: (1)
Re: heating stuck
Tethys
Not the thermostat, but the heater cock, probably. You could try a search on here for "heater cock".
I'd be inclined to leave the job until the spring. It's not a technically difficult job, but a high labour charge one because the heater is buried so deep in the car. Unlike the thermostat, it's a simple valve. I can't see it being connected to the service.
Old 10-02-2007   #5
Trader Rating: (0)
Re: heating stuck
Thanks a lot for your answer. I searched a bit through the forum and found a few un-lady-ly threads on that topic. Might indeed be the valve. What I don't understand: how can a damaged valve keep the radiator on a constant high temperature?
Tethys
tethys is offline
Old 10-02-2007   #6
fingers99's Avatar
Trader Rating: (1)
Re: heating stuck
The way it should work is that if the valve is closed, then there is no water flow through the heater matrix. The water in the heater matrix soon returns to ambient temperature.
The further open the valve is, the more water flow, the more heat transfer. The same as a domestic central heating system (at least, one where the radiators don't have individual thermostats).
The other possibility -- if the temperature control lever feels very slack -- is that the wire that opens and shuts the cock has just fallen off.
no heating in classic panda!!! Toolz with no Tools Panda (Classic) 16 12-12-2006 19:46
(G) Temperature / Heating / Cooling... stuart936 Punto 7 22-03-2006 12:35
(T) me 'eads stuck arc Cinquecento / Seicento 4 03-11-2005 21:30
(T) Marea ELX Driver's Electric Window Stuck OilBurner Marea 2 04-08-2005 01:31
Another heating problem... Simeon Panda (Classic) 21 08-03-2004 03:34
