The FIAT Forum
Old 09-02-2007   #1
Trader Rating: (0)
Please HELP injectors
cAN ANYBODY HELP ME PLEASE i am have trouble with my 2000 seicento sporting i have been told it is the injectors the car is constantly shaking and seems to be starved of fuel i have changed the ignition coil no difference cleaned carb still no difference and CHECK THIS the fiAT dealerships want £111 per injector MY DEAR LORD!!!!!!!!!!!
please help is it my injectors and where can i get them from haVE LOOKED IN SCRPYARDS ALSO
anybody got any for sale
also anyone doing any bulk buys on 15 alloys for seicento
thnx peeps
AzBo is offline
Old 09-02-2007   #2
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: Please HELP injectors
no
welcome to the forum
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 09-02-2007   #3
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
It is very unlikely to be be a duff injector they are useually very reliable
is an MPI model?
Has the fuel filter been changed lately?
BTW Welcome
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is offline
Old 09-02-2007   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
fuel pump?
AppleSei is offline
Old 09-02-2007   #5
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Which model is it, mpi or spi? Is a warning light on on the dash? Who told you it was the injector(s)?
I think it's a misfire of some sort. Try running the engine after dark, open up the bonnet and see if you can see any bright flashes (arcing) around the plug leads or plugs.
fingers99 is offline
Old 11-02-2007   #6
Trader Rating: (0)
the sei is A 2000 Y reg model car has recently been serviced so fuel filter has been changed shaking started off not too bad nwen iused 2 rev to 4000 it would stop now jus wont stop
please help
cheers
AzBo is offline
Old 11-02-2007   #7
fingers99's Avatar
Trader Rating: (1)
FCS, if you want help try what we suggest and give us more information. BTW, are you sure they changed the fuel filter?
Old 11-02-2007   #8
Fehler in alle Teilen
Fivehundred's Avatar
Trader Rating: (0)
Fivehundred has donated! United Kingdom
You need to diagnose whether its fuel or ignition. A misfire can also be caused by a failing coil pack. It is fairly easy to test the coils by using a timing light. Simply connect the timing light to each ignition lead in turn and abserve the pattern of flashing on a timing mark on the crank pulley. If one lead is misfiring you'll soon spot it visually.
Basically diagnose properly, then spend the money on the correct part.
Fivehundred is offline
(T) Injectors repaired! Amir Bravo / Brava 6 05-11-2006 22:41
(T) Turbo injectors. syrill-sneer Uno 3 18-12-2005 17:51
(T) Brava 1.8 16V injectors TBel Bravo / Brava 0 04-01-2004 06:56
