The FIAT Forum
Old 19-01-2007   #1
Eats, shoots & leaves
col7104's Avatar
Trader Rating: (1)
col7104 has donated! United Kingdom
Later Metal HG vs Std HG
Old on the left, new on the right.
Metal part number - 55189864
col7104 is offline
Old 19-01-2007   #2
MG ZR Owner :)
SkinzCinqSporting's Avatar
Trader Rating: (2)
SkinzCinqSporting has donated!
Re: Later Metal HG vs Std HG
Pic doesn't work for me?
SkinzCinqSporting is offline
Old 19-01-2007   #3
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
They do for me.
So, are the thicknesses the same or diffefrent?
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
Old 19-01-2007   #4
col7104's Avatar
Trader Rating: (1)
With a rule (haven't got vernier to hand), new one is 0.5mm as opposed to 2mm of the old style one.
col7104 is offline
Old 19-01-2007   #5
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
thinner gasket = higher compression
Higher compression = more power
Metal gasket = better able to cope with more power & longer life
there must be a downside somewhere
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is offline
Old 19-01-2007   #6
col7104's Avatar
Trader Rating: (1)
I've been trying (and failing) to find it too
col7104 is offline
Old 19-01-2007   #7
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
similar to head when skimmed to max it destroys the non interfierance charectaristic of the FIRE engine maybe?
and damn cant use on turbo need my low comp lol
Lots of mods Rev1 MR2 Turbo - Sold pending collection
RX7 Twin Turbo - Because real men play with twins
GhostWKD is offline
Old 19-01-2007   #8
Asteris's Avatar
Trader Rating: (0)
Greece
Higher compression means higher probability for knocking, especially for ECUs without a knock sensor. Proceed with caution...
Asteris is offline
Old 19-01-2007   #9
col7104's Avatar
Trader Rating: (1)
Yeah that did cross my mind. Have to use the more expensive fuels from now on methinks.
col7104 is offline
Old 19-01-2007   #10
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
head skimmed to max is still safe.
i think the CR would be around 10.9:1 if this was used on a 'std' 1242.
ive not worked through the math, but Balidey did and i've nicked some of his info there.
also, have you overlayed both gaskets onto each and checked everything is 100% correct, ive heard the oilways dont match
edit: CR is actually a bit lower than 10.9
arc is offline
Old 19-01-2007   #11
col7104's Avatar
Trader Rating: (1)
Yeah I've had them both over each other. Their a perfect match
col7104 is offline
Old 19-01-2007   #12
umop apisdn
balidey's Avatar
Trader Rating: (1)
You can run normal unleaded upto about 10.5 CR with out detonation probs. Over this then a good brand fuel is advisable, or an additive to raise octane is a good alternative.
I was looking for info on this HG a while ago, is that a FIAT part number??? It looks like just swapping the HG over with no head machining will give approx 10.3 ish CR, please note these are rough calcs i did a while ago without actually measuring the piston crown or head, but my head is currently in bits on my bench so i should be able to work it out more acuratly this weekend.
As a rough, and i mean rough, guesstimate, it looks like approx 1.5mm cabn come off the head (or block) without interference. Again, i can't check now as my cam and valves are all apart, but will measure and report back.
As for a disadvantage, you really need a vernier pulley as the head will be sat down further so the timing will be out. But if you have raised the compression to give more power then common sense tells you not to use the FIAT timing marks due to manufacturing tolerances so you should really use a vernier (or offset dowel etc) and a timing disc and DTI to set it up correctly or you could be losing more power than you could have gained with the raised CR.
Another disadvantage, i wouldn't advise using it if you have had any skim done at all or the CR could be way over what you want.
And finally, have you got a price?
balidey is offline
Old 19-01-2007   #13
col7104's Avatar
Trader Rating: (1)
Thanks for that info!
Price is £15.10, I think it's before VAT, that is a fiat part number.
col7104 is offline
Old 19-01-2007   #14
umop apisdn
balidey's Avatar
Trader Rating: (1)
Not bad price, seeing as a skim cost anything from £30.
I've just bought a new (standard) HG set so thats going on the 1108 and then i can look into getting one of these thinner ones for my 1242 when i get round to re-building it.
Thanks for letting us know.
balidey is offline
Old 19-01-2007   #15
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Is the metal one the SuperFIRE (1368) "super" gasket?
fingers99 is offline
(G) Why do I have a metal back of rear sets? Rabbit1986 Grande Punto 10 14-06-2006 12:43
Metal sub enclosure...benefits? T.E.D. Jordan I.C.E 5 21-03-2006 10:27
(T) fiat brava sx 80 14 hundred. Are the tensioners made out of metal? charton Bravo / Brava 0 13-06-2005 18:34
best way to drill holes in metal? Bushboy Leisure Lounge 33 12-04-2005 23:28
