The FIAT Forum
Old 12-01-2007   #1
Trader Rating: (0)
cinq117 has donated! United Kingdom
oil pressure guage
Hello everyone, i am new to the forum and i need some help(surprise surprise) anyway i have got myself a oil pressure guage, which comes with a sender. the sender thread size is 1/8. the problem is i don,t want to drain the oil and take the oil pressure switch off to findout its the wrong thread size. does anybody know if this is the right thread size and if not what is it so i can buy an adaptor. thanks
cinq117 is online now
Old 13-01-2007   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: oil pressure guage
Dunno what thread the warning light sensor is, but the other place to use is the bottom allen headed screw next to the oil filter. This is M18 so you need a M18 to 1/8bsp adaptor. Demon Tweeks, amongst others.
fingers99 is offline
Old 13-01-2007   #3
nitrane.co.uk's Avatar
Trader Rating: (0)
nitrane.co.uk has donated! United Kingdom
Hi, you're where i was about 2 weeks ago... the thread on mine was 1/8 NPT. I fitted a sandwich plate between the filter and pump. I had to tap out a blanking fitting to get it in correctly.
There's pictures of the set-up here... http://www.nitrane.co.uk/multimedia/albums/engine.htm
As said above, Demon Tweeks are a good source of bits and knowledge, and their service is pretty good too.
John
BIG Fiat... now on Facebook
nitrane.co.uk is offline
Old 15-01-2007   #4
The Thrill of Driving....
J333EVO's Avatar
Trader Rating: (0)
J333EVO has donated!
As finger said (he should have invoice for it in the records of blue) I got a M18 to 1/8NPT fittings for oil pressure from Demon Tweeks, utilising the bottom oil feed below oil filter take off, its blanked as standard with an Allen bolt.
Its made be LMA Motorsport on this page scroll down http://www.lma-group.com/motorsport/...ing_parts.html
ADAPTOR M18*1.5(M) to 1/8NPT(F) Short Style LMA067 £5.99
HTH,
Aaron.
1992 Lancia integrale EVO1;
1995 Toyota Celica GT4 ST205;
2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's)
J333EVO is offline
Old 15-01-2007   #5
Trader Rating: (0)
Thanks you guys, i bought a lma adaptor M18 to NPT 1/8 today and the guage works a treat. spot on . : This fiat forum is pukka. cheers again .
Old 17-01-2007   #6
Trader Rating: (0)
It seems that you have fitted the guage now, but you don't need to drain the oil to fit a gauge.
When you turn off the engine, just about all the oil drains down into the sump. The oil level is below the sump gasket level. Look how long the dipstick is.
There will be some oil stuck in the oil galleries in the engine, but there won't be much and draining the sump won't empty the galleries anyhow. You only need to drain the oil if you are taking the sump off for something.
Malin Dixon is offline
Old 17-01-2007   #7
Trader Rating: (3)
Out of curiosity, why did you use a sandwich plate rather than one of the oil feeds?
GoBe is offline
Oil Change bhinderharminder Leisure Lounge 4 08-10-2006 22:44
Instructions for oil change Koa Leisure Lounge 3 15-04-2006 03:49
How do perform an oil pressure test andymanmusic Lets Talk FIAT 2 09-03-2006 19:51
(T) Low Oil Pressure pjp Stilo 14 28-03-2005 15:10
