The FIAT Forum
Old 12-01-2007   #1
Trader Rating: (0)
Question Flywheel sensor stuck - fan belt removal ??
I hope someone out there can answer this as I’m a bit stuck.
About three weeks ago, after picking up some hints from this site I renewed the alternator on my daughter’s 1998 Seicento S – taking off the wheelarch splash covers it was no problem … except the heads to the Posi- headed fixing bolts securing the flywheel sensor in place both sheared – meaning I couldn’t slip off the old belt to renew it. Still the belt didn’t look too bad – so I left it on. Now, unfortunately it is slipping and needs replacing.
Does anyone know :-
A the size of the threaded fixing bolts on the flywheel sensor and do you think I could get them out with a bolt extractor bit set ?
B Could I just drill out the bolts (space very tight really)
C Is there any other way of getting the belt off and a new one back on ?
Strider52 is offline
Old 12-01-2007   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Flywheel sensor stuck - fan belt removal ??
you can just take the pulley off
Binki
dave is offline
Old 12-01-2007   #3
Eats, shoots & leaves
col7104's Avatar
Trader Rating: (1)
col7104 has donated! United Kingdom
Yah, just take the pulley off, don't have to disturb the sensor then. 62Nm to tighten them up again. Put it back on making sure the hole in the pulley corresponds to the pin on the crank pulley.
col7104 is offline
Old 12-01-2007   #4
Trader Rating: (0)
I did think about that but was a bit concerned about timing slipping - does the pulley come off fairly easily and is there only one way it fits back on ?
Cheers for the advice
Old 12-01-2007   #5
col7104's Avatar
Trader Rating: (1)
Timing won't be affected at all The alternator belt pulley is a seperate pulley which bolts onto the cambelt pulley. All will become clear when you take the three bolts off and pull the pulley away. It may help to slacken the alternator belt off by sliding the alternator to let you refit the pulley easier. However I did it without. It does only refit one way, but like I said, just line the pin with the hole and it'll work
col7104 is offline
Old 12-01-2007   #6
col7104's Avatar
Trader Rating: (1)
Forgot to add, you'll need to quite literally 'stick a spanner in the works' to stop the pulley from turning while you tighten/loosen the bolts.
col7104 is offline
Old 12-01-2007   #7
Trader Rating: (0)
Cheers I'll post details when the job's done
Timing Belt Replacement lightweightmick Panda (Classic) 14 21-03-2008 12:40
(T) When should my Seicento Sporting Cambelt be Changed? pippypower Cinquecento / Seicento 14 28-10-2006 15:31
(T) Photo how-to: Marea 20v cam belt change fixitagaintomorrow Marea 0 01-02-2005 14:20
(T) can a wrong fan belt stop a car starting? is_it_me Cinquecento / Seicento 14 03-01-2004 04:58
