| | #16 | |||
| The Thrill of Driving.... | Re: Strut brace on turbo keeps splitting fuel line :(
You have to ask yourself, what is more important, the fueling, or a brace. The MPi one looks a good bet to be clear by some margin. I think Emmas car has a KD Racing one which has loads of clearance as it sits very low, and have also used a OMP brace and had no issues.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | |||
| | #17 | |||||
| custodian of imola blue | Re: Strut brace on turbo keeps splitting fuel line :(
But why not rotate the whole plenum 180 degrees, chop off the intake and weld up the hole and weld it on the other side?
| | #18 | ||
| ' | Re: Strut brace on turbo keeps splitting fuel line :( A braided hose, or some thick much larger fuel hose who's ID is greater than the OD of the injector hose, just slip it over. Get one with think walls! Braided should be fine. A thick rubber hose will go over time, but shoudl last a LOT longer than the thin injector hose. Sacrificaial corrosion Just keep an eye on it every so often.Another alternative, more od a bodge but should work Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #20 | ||
| Scandinavian Passion.... | Re: Strut brace on turbo keeps splitting fuel line :( If you're thinking about changing the brace you could always get someone to make up a custom one using the SPI brace for aprox. stiffness of the tubing.
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit | ||
| | Littala | Cinquecento / Seicento | 5 | 10-01-2007 22:43 |
| | 4paws | Uno | 4 | 15-06-2006 17:16 |
| | _CinqueCento_ | Cinquecento / Seicento | 1 | 01-02-2005 15:56 |
| | chrisunoman | Uno | 10 | 04-05-2004 20:19 |
